Probably not.
Why wouldn't you upgrade the controller to something that is actually supported? AOS 6.5 is EOL.
The AP-503 needs AOS 8.11.1.0 at least, minimum running version at this point should be the latest 8.12.x.x release.
Carson Hulcher, ACEX#110
Original Message:
Sent: Sep 10, 2024 09:14 AM
Subject: RAPNG with AP503
we have implemeted a RAPNG-solution with Aruba 7010 controller running an AOS 6.5.4.24 and a couple IAP-cluster running on 8.10.0.13. This is working fine.
Now we have a request to add an IAP-cluster of AP503 that is running on AOS 8.11.02. The L2TPover IPSec-Tunnel is not comming up.
Is there any chance to get this up and running without upgrading the controller?
Kind Regards
Uwe
