Wired Intelligent Edge
Re: AOS-CX Tech Tips: "allow-unsafe-updates"
  • 1.  Re: AOS-CX Tech Tips: "allow-unsafe-updates"
    Posted Oct 24, 2020 08:37 AM
    I figured it out and was able to make the switch install all the pending updates.
    The procedure I had to follow was:
    - enable allow-unsafe-updates , and reboot the switch
    - then, re-enable allow-unsafe-updates and remove the power from the switches
    - then reconnect power to the switches
    The missing step here was that I took more than the allow-unsafe-updates <timer> to remove the power.
    Still I think that requiring a full power cycle (physical re-plug the power cable; can't do it with a soft reboot), forcing admins to go on site and to every single technical room to remove power cables, is an unacceptable requirement for enterprise level campus switch and a bit of, well, a joke.
    Is there any plan to remove this requirement?
  • 2.  RE: Re: AOS-CX Tech Tips: "allow-unsafe-updates"
    Posted Oct 26, 2020 11:55 AM
    This is, to my knowledge, unique to the 6405 and 6410 — infrequently, component firmware updates on these models require a full power cycle of the switch chassis to complete the update process.
    I am feeding this back to engineering to determine if there is a plan to eliminate this requirement for future updates, and to recommend that the power-cycle requirement is clearly documented where applicable.
