  • 1.  Re: Increasing tinyproxy's connection timeout
    Posted Jan 09, 2017 11:40 PM
    We are using Aruba IAPs
  • 2.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 09, 2017 11:29 PM
    Aruba is using tinyproxy behind the scenes to parse external captive login page and look for success text.
    From my experiments, it seems that tinyproxy connection timeout is set to 5 seconds by default which may not be enough in some cases (it's not enough in my case). After 5 seconds, the connection is abruptly closed and CNA doesn't understand what just happened.
    I'm trying to find a way to increase the timeout, so far no luck.
    Any ideas?
  • 3.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 09, 2017 11:36 PM
    What product are you referring to?
  • 4.  RE: Re: Increasing tinyproxy's connection timeout
  • 5.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 10, 2017 07:15 AM
    What are you trying to do?
  • 6.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 10, 2017 07:24 AM
    I have an external splash page and authentication method is set to 'authentication text'. My external page on some occassions takes more than 5 seconds to spit out the final confirmation text due to external API calls, and Aruba (or tinyproxy) in such cases simply drops the connection after 5 seconds.
  • 7.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 10, 2017 07:47 AM
    To be clear, are you saying that your page is taking more than 5 second s from "submit" to finish and you want to extend the timeout?
  • 8.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 10, 2017 04:59 PM
    Dear Colin,
    Yes, that's exactly what I'm saying.
    Just to be clear, we are not using RADIUS authentication, we rely on 'successful text' method.
  • 9.  RE: Re: Increasing tinyproxy's connection timeout
    Posted Jan 10, 2017 05:01 PM
    Got it.  Let me check..
