Read more certificate attribute values to Computed Attributes
  • 1.  Read more certificate attribute values to Computed Attributes
    Posted Dec 13, 2023 09:43 AM
    Hi
    I have a use case for a customer where I would like to assign roles in the role mapping policy based on attributes that are not visible by default under Computed attributes.
    For example I would like to read the attribute Certificate Template Information and based on the template used for the specific certificate assign roles. In this case devices get certificates based on different templates, depending on the device type.
    Is it possible to add more attributes from the certificate into the Computed attributes, or does this require a feature request?
    Best Regards
    Jonas Hammarbäck
    MVP 2023, ACEX, ACDX #1600, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACSA
    Aranya AB
  • 2.  RE: Read more certificate attribute values to Computed Attributes
    Posted Dec 14, 2023 05:41 AM
    That would be a feature request as far as I understand. Please check/open one in Aruba Innovation Zone.
