Dear Jerrod Howard,
First of all, thanks your help..
[Your Question]
So mixing mcast and unicast over the mesh link can possibly create some issues with the multicast traffic (hard to know for sure). What are you seeing? Is one better than another or are they both having issues?
<My Answer>
Our major traffic is multicast. The unicast traffice is so small. So I didn't see any problem.
Would you tell me some potential problem we will exptected?
[Your Question]
When you run an iPerf test over the link, what kind of throughput are you seeing across the link (both TCP and UDP)?
<My Answer>
I got maximum 500Mbps distance 45m.
