  • 1.  Recommended EIRP
    Posted Mar 13, 2021 09:30 PM
    recommended
    What is the Recommended EIRP?
    I have found the following post but it dates back to 2015 and am therefore wondering if these values still apply?
    Airheads Community
    Airheads Community remove preview
    Airheads Community
    Hidden page that shows all messages in a thread
    View this on Airheads Community >
    Any idea where I could find this info because otherwise I won't find anything about it.
    Thanks in advance.
    Kevin Goemaere
  • 2.  RE: Recommended EIRP
    Posted Mar 14, 2021 02:44 PM
    Edited by mkk Mar 14, 2021 02:44 PM
    Hi Kevin,
    Unfortunately, there is not one simple answer for every situation.
    Normally you keep the EIRP transmit power equal to your client device with the lowest maximum transmit power. Typically a mobile devices have a maximum transmit power of about 30mW / 15dBm because these types of devices have to conserve their battery life.
    To get the cell size of the 2.4 and 5GHz radio equal, you have to calculate 6dBm less for the 2.4GHz radio.
    You will usually be fine with the settings below for a standard office, but I can be different in every situation.
    2.4GHz
    min.6dBm
    max 9dBm
    5GHz
    min.9dBm
    max. 15dBm
    As long as your clients have a good signal strength (around -60dBM and -65dBM mimimum) and no co-channel interference occurs, you're fine.
    <c-wiz jsrenderer="xuEY0" class="rm1UF UnxENd dHeVVb" jsshadow="" jsdata="deferred-c1655" data-p="%.@."","",""]" jscontroller="M2suMc" jsaction="fgP5ge:reBGj,fO5Jj;SuwQzc:psubsc;ZJRbqd:R99J9b;PPMpVe:Ro8hud;iRXaId:vQ5fhd,QHu6Rd,g1rTCe,hHjFBe;WUl1Sc:Lt1lf;ETwhqd:ohO51;xlKgVc:sz93Ff;auJseb:IV7LWe;pNe98e:B1XqVb;xFfZGc:fO5Jj;OQcvYd:o9EnMb,lXvwxb;sT00Fe:Nrlepe;K1idad:ueU8Ab;MFfQNe:XTf7qb;n3ynxb:tQNmWe;k9TsOe:PCDOwc;RRMwLc:Fg8W1e;mG3QHf:OYLrVb;Qz4V0b:hQ7xdc;fBzasf:YoknPd;UgEtGb:hQ7xdc;h5CHLc:i5R1S; click:gx3W4c; touchend:Ui18c;h1Uxi:qx6Cqc;PF39hf:gx3W4c;HmXuze:peH7Nc;FvQNXc:T2uEDc,J6gWY;zOKmBc:rV2CEd,ZQTNrf;NC92Xd:t0GU7d,UbDGRc;XZiffb:MEUYed,ZcXqnb;tt7Sbd:XTdsoc;" data-node-index="2;0" jsmodel="hc6Ubd LP4cEc">
    </c-wiz>
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: Recommended EIRP
    Posted Mar 15, 2021 05:04 AM
    Ok thanks.
    Kevin Goemaere
