Have a simple network, with core being stack of Comware based 4 x 5900AF, which does the routing
Each edge cabinet (with Aruba 2920 stacks with latest firmware WB_16_10_0011) connects via single direct fibre OM4 10Gb to the core
All works fine, but as I have some spare (different route between buildings) fibre links available between cabinets, I would like to connect edge cabs between themselves for redundancy.
Last time I did that, all hell broke lose, core lost communication to almost all the cabs, even one of the Hyper-V directly connected to the core dropped off. To get it all back to working state had to drastically reboot the edge cabs & even the core!
Spanning tree is enabled on all switches, as is loop protection (per Vlan)
Core is (and was) definitely a root bridge
What else am I missing (having a blackout, sorry) to have the links between (just in case the main one goes down)
Seb
