  • 1.  registration token
    Posted Jan 23, 2015 02:05 PM
    I am trying to setup a registration token field in a self-registration page but am having difficulty getting it to work so any advice would be appreciated.
    Basically I have added a field using the prebuilt register_token field and set the validator to "IsIdentical"  and set the registration word in "Validator Argument " box but it is not working so I guess I am doing it wrong.
    thanks
  • 2.  RE: registration token
    Posted Jan 23, 2015 02:51 PM
    I don't think the register_token field is what you want to use, that is a field used by the system .   Are you just looking for the user to supply some sort of predefined "code word" to be granted access?
    Try creating a new field and adding it to your form:
    Field Type: string
    User interface: Text Field
    Label: Enter Secret Code
    Field Required: yes
    Validator: IsEqual
    Validator Argument: "your code word"
  • 3.  RE: registration token
    Posted Jan 23, 2015 03:04 PM
    Thanks thats done the trick :)
  • 4.  RE: registration token
    Posted Dec 23, 2019 08:59 AM
    Possible to have  this code word change or be random at the start of each day or meeting?
    Field Type: string
    Field Required: yes
    Validator: IsEqual
