Remote AP cannot establish a connection with the 9240 controller using IPv6.
  • 1.  Remote AP cannot establish a connection with the 9240 controller using IPv6.
    Posted Jan 09, 2025 09:50 PM
    Aruba Remote AP cannot establish a connection with 9240 controller using IPv6.
    The same situation occurs when AP uses 305 and 505. Their flags always stay at Rc2ID.
    But there is no problem with AP and Controller 7240XM in the same environment.
    The current version is: 8.10.0.13
    Is this a version support issue or is the controller itself not supported?
    Has anyone encountered the same problem?
  • 2.  RE: Remote AP cannot establish a connection with the 9240 controller using IPv6.
    Posted Jan 10, 2025 11:29 AM
    I would recommend opening a case with TAC on this.
    Carson Hulcher, ACEX#110
