You will need a VPNC (gateway physical or virtual) in your datacenter. Then configure microbranch on AOS10. There are detailed videos in Airheads channel how to do this.
Here is the first video in the series SD-BRANCH from scratch.
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Apr 20, 2023 05:36 PM
Subject: Remote APS and Aruba OS 10
Hello i was wondering how this works?
Back in time i used to configured with 6.4 my remote APS and all that, i belaive its the same with aruba OS 8
But what happens with Aruba OS10 which the managment is on the cloud, can i do the same with aruba controllers with WLANGAteway license with microbranche?
I would like the expirience of extending my vlans of the office to my remote sites if that is possible with the same SSID like i used to do with the 6.4
