SD-WAN
  • 1.  Remote Log Receiver
    Posted Jan 20, 2025 09:34 AM
    Hello, I need to configure a 'Remote log receiver' in orchestrator using webhooks. I want to see all logs of the devices in XSOAR machine. The connection with my xsoar is a webhook receiver. The connection to the webhook is using port forwarding on the proxy to port 8443. I am not receiving any alerts on my server even though the ports are open, do you know if there is a problem with port 8443 for the connection in the platform configuration? I have tried with another server that I have pointing to port 443 and there I was able to receive the events.
    Thank you
    Rosa
  • 2.  RE: Remote Log Receiver
    Posted Feb 18, 2025 01:53 AM
    Edited by Khwaja Mohammed Feb 24, 2025 12:39 PM
    Hi Rosa,
    In Silverpeak Orchestrator, the "Remote Log Receiver" feature supports webhooks; however, there is a known limitation or restriction when using port 8443 for webhook connections. Due to this, syslog messages are not being transmitted successfully.
    For your reference, please find below the official documentation outlining the TCP/IP ports used by Orchestrator and EdgeConnect appliances:
    Aruba TCP/IP Ports Documentation
