Network Management
remote mirror between 2 different vendors
  • 1.  remote mirror between 2 different vendors
    Posted Apr 07, 2025 04:51 PM
    Hello
    Was wondering if the below is possible
    need to setup remote mirror between Core - AOS-S ( 3810M) and Comware 7 (5900)
    mirror source will come from 3810 sent to 5900 that has the appliance connected to analyze the packet
    I have these commands as examples that  I am seeing from both vendors guides
    thank you
    Aruba:
    Syntax
    mirror <SESSION> <session> remote ip </session><SRC-IP> <SRC-UDP-PORT> <DST-IP>
    interface <PORT>
    monitor <all>
    Description
    Configures a remote mirroring destination
    Comware:
    # Create a remote destination group.
    [DeviceC] mirroring-group 2 remote-destination
    # Create VLAN 2.
    [DeviceC] vlan 2
    [DeviceC-vlan2] quit
    # Configure VLAN 2 as the remote probe VLAN for the mirroring group.
    [DeviceC] mirroring-group 2 remote-probe vlan 2
    # Configure FortyGigE 1/0/2 as the monitor port for the mirroring group.
    [DeviceC] interface fortygige 1/0/2
    [DeviceC-FortyGigE1/0/2] mirroring-group 2 monitor-port
  • 2.  RE: remote mirror between 2 different vendors
    Posted Apr 08, 2025 12:44 AM
    On Source Side, Aruba 3810M with ArubaOS (but make sure mirror 1 is configured before applying it on the interface):
    mirror 1 remote ip 10.10.10.1 1234 10.10.10.2
    interface 1/1/1
       monitor all both mirror 1
    On Comware,
    vlan 2
    interface Vlan-interface2
       ip address 10.10.10.2 255.255.255.0
    interface FortyGigE 1/0/2
       port access vlan 2
    Usually, according to what i have read, Comware does not support decapsulation of UDP natively. It only supports local port mirroring and remote mirroring using remote-probe VLAN. So in this case, you need to terminate the UDP packets (as for example a dedicated analyzer behind the Comware switch) or just forward the mirrored UDP packets untouched through a dedicated VLAN to your analyzer.
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
