Hi
Changing the colors of the page is done by setting a skin for the page and then update the skin parameters.
Select the skin under Guest\Administration\Login Configuration.
Select a skin from the Login Skin drop down:
Assume Custom Skin 1 is selected, navigate to Administration\Plugin Manager and scroll down to Custom Skin 1.
Click Configuration. Note, do not click Enable. This will enable the skin as the administrative GUI skin instead of the default skin. If clicked by mistake, restore by enable Aruba ClearPass Skin.
In the skin configuration update the colors as needed
Renaming the title of the login page is a bit trickier, but I you can do it this way, even if it feels like a strange way to do it...
- Navigate to Configuration\Translations\Language Packs. Select English Translations
- Click Translations under the language pack
- In Text IDs box type the number 25 and press enter
This will give you one additional box 25: under Common IDs as shown in the screenshot above.
- In the text box enter Employee Login and save
- Verify the updated text
- If you have users with other languages in the web browsers, the page will be translated automatically if the language is supported by ClearPass. In such case the process must be updated for each language the users have
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: Feb 13, 2025 07:21 AM
Subject: Rename Operator Login
Good day!
I would like to ask how I can change the operator login to the employee login. Additionally, could you please guide me on how to change the background color to blue instead of gray?This from guest/auth_login.php
Thank you!
