Community Feedback
  • 1.  Rename Operator Login
    Posted Feb 16, 2025 08:36 AM
    Good day!
    I would like to ask how I can change the operator login to the employee login. Additionally, could you please guide me on how to change the background color to blue instead of gray?
    Url: 10.172.XX.XX/guest/auth_login.php
    Thank you!
  • 2.  RE: Rename Operator Login
    Posted Feb 16, 2025 10:48 AM
    You need to go ClearPass Guest > Administration > Operator Logins > Login Configuration
    Then you have the Login Skin.
    There is a thread related to this: https://community.arubanetworks.com/discussion/clearpass-guest-custom-skin-center-login-page
    Also there is this link: https://arubanetworking.hpe.com/techdocs/ClearPass/6.12/Guest/Content/AdministrationTasks1/ConfiguringArubaSkinPlugin.htm
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: Rename Operator Login
    Posted Feb 17, 2025 10:08 AM
    Did you see/check the answer to the question that you asked earlier?
