PCM was replaced by IMC many years ago, and that is still the recommended solution if you need to manage legacy ProCurve switches like 2510/2610. It comes with a 60-day free trial so you can see if it works for you. You could also try opening a TAC case to have the PCM licenses transferred. While there's no more support for PCM in terms of fixes and features, licensing transfers may still be handled.
Justin Guse
Original Message:
Sent: Nov 15, 2022 06:13 AM
Subject: Replace PCM
I have a network of old Procurve switches that i will try to replace.
My PCM server broke down and now i cant activate a new PCM server and move the license. Is it still possible to activate a license? I mean it needs to be approved by HPe i think?
Is there any new management software that can manage my old Procurve switches (2510-2610 and so on)?
