Thanks.
Original Message:
Sent: Oct 17, 2024 05:57 AM
Subject: Replacing 325s with 635s
And be sure to have enough PoE power to power those beasts. PoE+ should in most cases be sufficient but check with PoE budget on the switches. Also ethernet ports on 635 are SmartRate up to 2.5G. 1G eth ports will not be able to really utilize those APs.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Oct 16, 2024 06:53 PM
also note that the mounting kits for the AP-325 and AP-635s are different.
Original Message:
Sent: Oct 16, 2024 03:03 PM
I don't know how close you are on AP licenses and if your plan to pre-provision AP's or not, but I'd suggest asking your Aruba rep for a block of temp AP licenses. That way you'll always be compliant and not get any of those pesky licensing messages. For me, I try to do pre-provisioning so I can make sure AP's are already upgraded, named and placed in their future AP group (and if using Airwave VisualRF, placed appropriately on the floorplan), limiting the possibilities of "in the field" OS update disruptions, especially during mounting.
Original Message:
Sent: Oct 15, 2024 05:33 PM
AP-325 or AP-365?
The AP-635 is an indoor only AP.
Disconnect the old AP from the network, plug the new AP in, nothing else required for licensing. You can delete the old APs from the controller/MCR once they show as offline.
Carson Hulcher, ACEX#110
Original Message:
Sent: Oct 15, 2024 01:22 PM
General question: I have to replace our AP-365s with Ap-635s. Is there certain tasks that need to be done to remove the licenses from old APs, remove old APs from controller database and add new APs to ensure they receive a license?
Peter
