I edited the configuration of the main cluster and added allow AP MAC table to have the new one and rebooted everything and no dice.
I also set the IP manually in the GUI for the new one and rebooted and it is still just doing its own thing. I tried to put on the config from the other one as well with no luck.
It sounds like I need to reset it and assign an IP before boot, but I am having problems consoling into it with the aruba console cable and putty.
Drew Kenton
Original Message:
Sent: Feb 11, 2021 05:15 PM
Subject: Replacing an IAP 207 and having trouble
Does your Wifi LAN have DHCP? If not try factory resetting the AP, and assign the static IP with this method: https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=5981ce86-e40d-4611-8da9-263e8bd9b9e5
You don't want the AP getting to a point where it thinks its is own VC, and a separate cluster. Assign the IP before boot, and let it discover the VC and join.
Dustin Burns
Original Message:
Sent: Feb 11, 2021 02:57 PM
Yes, auto-join is enabled on the new AP and on the master. I wish it would let me manually add it.. The plus button is greyed out.
Drew Kenton
Original Message:
Sent: Feb 11, 2021 01:35 PM
Do you have Auto-Join enabled? If not you will have to manually add the AP on the VC. See Auto-Join setting below:
Dustin Burns
Original Message:
Sent: Feb 10, 2021 10:37 AM
I had one of our AP's die after a power surge and I bought a replacement and I am having trouble getting it to join the VC. I have followed the steps and the + button under Configuration\Access Points is greyed out. I read online that this is because the firmware is not the same. I went ahead and installed the same firmware that the other ones have and it is still not showing up. I have assigned the IP statically and in the same range as the rest of them. When it is on my normal staff network the SetMeUp Wireless network shows up. When I plug it into a port that is on the Wifi VLAN like the rest of the devices it never shows up. Any advice on how to get this working?
Drew
Drew Kenton
