Replacing cluster. Going from AP-205 to AP-635
  • 1.  Replacing cluster. Going from AP-205 to AP-635
    Posted May 31, 2023 04:06 PM
    Please forgive me if this scenario has already brought up.
    We have a large cluster of IAP-205 access points that we plan to do a 1-to-1 swap out with with new AP-635 APs.
    The current AP-205s are running firmware 6.5.4 and the new APs are likely running 8.x.x.   Will the AP-635 downgrade to version 6.5.4 version as it joins the cluster.  I'm not sure if the AP-635 supports 6.5.4.x
    Just trying to figure out the easiest and painless process with minimal network switch configuration for this migration.
    Thanks!
  • 2.  RE: Replacing cluster. Going from AP-205 to AP-635
    Posted May 31, 2023 06:28 PM
    No the AP-635s will not downgrade. The min firmware that  they support is InstantOS 8.9.0.0
    i suggest connect one fo the AP-635s to a different subnet and  replicate the configuration from your APs and then test it.
    once you are happy with yhe test outcome then replace IAP-205s with it.
