What model of 2930F are you using?
The chart you have indicates that you are trying to connect a 4858 to a 9152. You cannot connect a 1g sfp to a 10g sfp.
Are these original Aruba parts?
Original Message:
Sent: Mar 07, 2023 10:31 AM
Subject: Replacing HPE 3500yl-48G-PWR Switch with Aruba Stack 2930F
I have been trying to replace an HPE 3500yl-48G-PWR Switch with Aruba Stack 2930F connected to a HPE 5412R zl2 Switch. The HPE 3500yl-48G-PWR is currently connected over a OM1 Fiber SC - SC fiber connection in the card on the back of the device to the HPE 5412R zl2 Switch in the 1 GbE/10GbE SFP ports using a J9152A 10G SFP. This connection works and shows the proper link lights. Using the same run I have attempted to connect the Aruba Stack 2930F. I first attempted to make the connection using a J4858C 1G SFP and OM1 fiber but realized that the compatibility may be the issue. I then tried a J4858D-GT 1G connected to the 2930F switch and used an OM2 fiber because it is what the SFP is compatible with. This still did not work. I had checked the configs on all devices and can not find any indication on why this connection may not be able to be made or even recognized as being plugged in. I also check logs with the same outcome. I see logs for the SFP hot swaps but no other indications of changes or issues. For the sake of trying everything, I tried the following combinations. I know some of these combinations do are not compatible combinations but I was attempting all combinations. Any suggestions would be appreciated.
Aruba Stack 2930F<o:p></o:p> | HPE 5412R zl2 Switch<o:p></o:p> |
SFP <o:p></o:p> | Fiber <o:p></o:p> | SFP <o:p></o:p> | Fiber <o:p></o:p> |
J4858C 1G <o:p></o:p> | OM1 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM1 <o:p></o:p> |
J4858D-GT 1G <o:p></o:p> | OM1 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM1 <o:p></o:p> |
J4858D-GT 1G <o:p></o:p> | OM2 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM1 <o:p></o:p> |
J4858D-GT 1G <o:p></o:p> | OM2 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM2 <o:p></o:p> |
J9150D-GT 10G <o:p></o:p> | OM3 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM2 <o:p></o:p> |
J9150D-GT 10G <o:p></o:p> | OM3 <o:p></o:p> | J9152A 10G <o:p></o:p> | OM3 <o:p></o:p> |
J4858D-GT 1G <o:p></o:p> | OM2 <o:p></o:p> | J4858C 1G <o:p></o:p> | OM2 <o:p></o:p> |
J4858C 1G <o:p></o:p> | OM3 | J4858C 1G <o:p></o:p> | OM1<o:p></o:p> |
