Network Management
  • 1.  Reporting data by work hours
    Posted Jun 15, 2017 12:30 AM
    Hi all, i currently new on airwave, currently i using AirWave Management Platform 8.2.2.1, and i took some generated report, is there any way to soring it by work hour or weekday, example every 08:30 am to 5:30 pm every monday to friday, thank you
  • 2.  RE: Reporting data by work hours
    Posted Jun 15, 2017 05:13 AM
    Hi ,
    We could run a report for specific time and also schedule the same report for daily, weekely and monthly in Reports>Definition page. Select any report type from drop down list and check below screen shot options.
    Pavan
  • 3.  RE: Reporting data by work hours
    Posted Jun 16, 2017 03:44 AM
    Thank you for your reply :), btw can i doing sorting on home > apprf menu?
  • 4.  RE: Reporting data by work hours
    Posted Jun 16, 2017 05:42 AM
    Airwave default retain 30 days of AppRF data, in AMP Setup> General >Historical page>
    AppRF Data Retention Interval (1-30 days):
    We could check the historical data on Home>AppRF page for 2hours, one day, one week, two weeks and also we could sort based on date.
    We could also run AppRF report from Reports>Definition page.
    Pavan
    If my post addresses, your query give kudos:)
