Network Management
  • 1.  Reports generated showing EDT timezone
    Posted Apr 18, 2018 11:45 PM
    Hi All,
    Last week we upgraded our Airwave server from 8.2.1 to 8.2.6 and ever since then our reports are showing its timezone in EDT. I have manually set the timezone on the server to AEST. When I issue the date command it shows the correct date and time but the reports show up in EDT.
    Can you please guide me on where else should I be changing the timezone in? I previously did the change using the ampadmin logon.
    Thanks in advance for your assistance.
    Kanes.R
  • 2.  RE: Reports generated showing EDT timezone
    Posted Apr 24, 2018 09:02 AM
    Are you seeing current time in AEST in report defintion and also in system>performance page? If Yes the
    Use the service command to start the rsyslog service.
        # service rsyslog start
    Use the chkconfig command to ensure the rsyslog service starts automatically in future.
        # chkconfig rsyslog on
    If issue still persist restart AMP services from System>Status page and check the status. Try open TAC ticket if above resolution does not fix the issue.
  • 3.  RE: Reports generated showing EDT timezone
    Posted Apr 24, 2018 10:00 AM
    In 8.2.6 code we have blocked CLI root access, you can try restart all the services from ampcli advanced menu or system>status page and check the status
  • 4.  RE: Reports generated showing EDT timezone
    Posted Apr 25, 2018 03:08 AM
    Hi All,
    I have managed to get this fixed after restarting the AMP services from the GUI. Sorry for the late update.
    Hi Pavan,
    Thanks.
