Comware
Reset Settings (factory default)
  • 1.  Reset Settings (factory default)
    Posted Sep 09, 2009 08:19 AM
    How to perform a reset (factory default) switch on a 4210?
    #Passwordreset
  • 2.  RE: Reset Settings (factory default)
    Posted May 25, 2010 01:16 AM
    no any information here? any answer from 3com?
  • 3.  RE: Reset Settings (factory default)
    Posted May 25, 2010 10:34 AM
    You just need to reboot the switch already connected to the console, and break the boot sequence usingthe keys CTRL+B. Then choose in the menu that will appear the option to reset the settings to default.
    HTH
