I need the help of an aruba Rest Api dev.
Could you tell me if the value stored in "is_port_enabled" when you call the REST URI "/ports" should indicate the administrative state (enabled/disabled) of a port even if it's a manual "change" or an auto "change" (BPDU protection for example) ?
In my test, it only get the manual change.
The web console display and the "show interfaces brief" command are fine.
I'm using stacked 2930F (x3) with firmware version WC.16.10.0002.
Thanks.
