Hi all,
I want to post firmware images on 6300 switches using a REST call in python.
The example from the API guide doesn't seem to work (I think the example is still using an old API?):
https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=emr_na-a00091710en_us
The API help on the switch ( https://{switch_ip}/api/v10.04 ) doesn't really help either.
So I have some basic questions. Do I upload the firmware in the post request in binary form or do I post a link to the file, where the switch needs to download it? If it's the latter, which protocol is used for the download?
I got the idea because of the documentation:
"file": [
"string"
It says string instead of binary file.
Did someone already upgrade their switch via API?
I tinkered a lot with the code, most of the times I get the error response 500 "Error processing the form.
Here is the current code, if you are interested.
firmware = os.path.abspath(firmware)
params = (
('image', 'secondary'),
files = {'file': open(firmware, 'rb')}
headers = {
'accept': '*/*',
'Content-Type': 'multipart/form-data',
r = session_dict['s'].post(target_url, files=files, headers=headers, params=params, verify=False)
Bjarne
