AOS 8.10.0.16
MCR and Standby MCR
Active and standby cluster (x2 - separate systems)
I am just looking over our config for AirGroup (centralised), we set this up quite a while ago. We use it in conjunction with device registration on ClearPass. I noticed that my notes say that OpenFlow should be enabled, and it is - but not actually for all VLANs (or at least not all VLANs that we want to participate in AirGroup are listed as bind-vlans). Is this required? I'm (fairly) sure whatever document we worked from first time around specified OpenFlow should be configured in this way, but when I look through docs now it doesn't seem to be mentioned.
What happens if VLANs aren't added to the openflow profile? Is there a definitive doc I can work from to check our config?
Thank you,
Guy
