in AOS10 11v is enabled by default.
Also note that with AOS8.x IAPs, 11v works with clientMatch service so you need to enable.
Original Message:
Sent: May 14, 2024 09:21 PM
Subject: roaming 11v not working?
and I haven't found the bottom to enable 11v in AOS 10, is it canceled in OS10 ?
Original Message:
Sent: May 14, 2024 07:48 PM
is this for Instant APs? and does your clients support 11v?
Original Message:
Sent: May 13, 2024 09:34 PM
I use two Aruba APs,and configure them with the same SSID name, password and encryption type, and activated the 11k and 11r , but cell phones didn't roam smoothly between two APs,keeping connecting to one AP even if I walkd closed to the other and received RSSI of connected AP is pretty low. So I use wireshark to caputure the wireless packets, however, there's no 11v frame captured, does APIN0555 support 11v? and how can I activate it to assit clients to roam?
