  • 1.  Roaming with Spectralink 8440
    Posted Feb 07, 2013 10:31 AM
    Have a Aruba controller 3200 with AP-105:s, Running a WLAN for Polycom spectralink 8440 wi-fi phones.
    I have problems with roaming between AP:s it takes the phone like looooong time before it switch to new AP.
    And the speech is cut until it recive the new AP...
    Any ideas?
    #3200
  • 2.  RE: Roaming with Spectralink 8440
    Posted Feb 07, 2013 01:40 PM
    There are a lot of variables that could be causing this.  To start, have you looked at the Optimizing Aruba WLANs for Roaming Devices VRD?  There are some specific recommendations for Spectralink 8020/8030, not 8440, but the principals may be the same.   Polycom also has a Configuration Guide for Aruba and does cover the 8440.
  • 3.  RE: Roaming with Spectralink 8440
    Posted Feb 18, 2013 03:09 AM
    Roaming is now ok.
  • 4.  RE: Roaming with Spectralink 8440
    Posted Feb 18, 2013 12:24 PM
    Thanks for the update.  Did the guides help?  Was there any particular settings that made a difference that you could share for future reference?
  • 5.  RE: Roaming with Spectralink 8440
    Posted Feb 25, 2013 10:14 AM
    It seems like when the phone is not in an active call it dont roam as it do when its in a call. And i guess maybe thats a power saving mechanism. We also tried to get the all the channels in subband3 only for faster roaming. So 1 step closer i know working on another issue:) but in separate post. Thanks alot for ur support
