Role-Based Vlan Pools
  • 1.  Role-Based Vlan Pools
    Posted Mar 24, 2013 02:12 PM
    Is there a way to set a server rule under an Authentication Server Group so that a user gets assigned to a VLAN Pool as opposed to just specific VLAN?
  • 2.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 02:16 PM
    There is not a way at this time.
    You may decide that you want to assign a group of users a different role, but just allow them to consume the same pool under the VAP.
  • 3.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 02:54 PM
    Thanks, can you elaborate on how I could achieve what I'm looking for?
  • 4.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 03:28 PM
    As Colin mention this type of setup unfortunately is not possible at the moment
  • 5.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:01 PM
    Okay.  I thought there might have been an alternative method to acheive what I wanted by this comment.
    "You may decide that you want to assign a group of users a different role, but just allow them to consume the same pool under the VAP."
  • 6.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:04 PM
    The question is.... What are you trying to accomplish?  What is your situation?
  • 7.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:09 PM
    I would like to assign students who authenticate via 802.1x to be assigned to a VLAN Pool on the same SSID as everyone else.    As opposed to just a single VLAN.
  • 8.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:12 PM
    Okay, so you might want to turn it around, then:
    Assign a pool of VLANs to the Virtual AP.  If a student authenticates via 802.1x just allow them on the radius server side or assign a role that does NOT have a VLAN assigned.  For others, you can assign them to a role that has a single VLAN tied to the role:
    Your Virtual AP has vlans 10,20,30.
    When your students authenticate, they will end up in one of those VLANs.
    Say a faculty member authenticates, you can respond with the radius server with a single VLAN that you want faculty in, or a role that has a single VLAN tied to it.
    Does that make sense?
  • 9.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:40 PM
    Absolutely.  I definitely follow your logic.
    Until they come out with the ability to do the role based stuff then I wouldn't be able to assign staff to a pool using the same SSID.
    Thanks for all your input!
  • 10.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 04:42 PM
    If it will make you feel better, we have people using /22 networks with "drop broadcast and multicast" enabled on the VAP/VLAN and they have not had performance issues to speak of.  In other words, a single larger VLAN would be a supported move.
  • 11.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 05:14 PM
    That does.. There is a chance we could go 1-1 with iPads, about 900 extra devices....and I'd like to break it up as much as possible.
    I'd just like to be as ready as possible for a large deployment.
    Thanks to you and everyone else being patient with me.  I'm learning a lot from you all!
    Chad
  • 12.  RE: Role-Based Vlan Pools
    Posted Mar 24, 2013 02:44 PM
    Based on the information provided at the airheads conf this will available in the 6.3 AOS code
