You will want to configure user roles and policies below the /md level (best practice to leave /md level at default). For example at /md/Company or /md/Company/SiteA. Config at the /mm or /mydevice level do not propagate to the /md levels. They are two separate branches of the config.
Dustin Burns
Lead Mobility Engineer @WEI
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
Original Message:
Sent: Jan 04, 2022 08:51 AM
Subject: Roles and Policies Rules Don't Match Up
I just noticed that my Role and Policy rules are different depending on whether I'm viewing them on Mobility Master or the controller name. Is there a way to force the rules to flow down from the Mobility Master to the controller so that they sync up? I'm guessing at some point I made rule changes on the controller level and not the mobility master level which has lead to this.
Seth Turner
