Comware
  • 1.  Routing between vlan switch layer 3 hp
    Posted Oct 06, 2018 08:35 PM
    Routing between vlan switch layer 3 hpHi friends, can you help me with a question that should be very simple for you? In work I have a layer 3 switch that is my gateway for vlan 1 which is the 172.16.0.3/16 main, I have created a vlan 20 172.20.0.1/26. I have configured a port for vlan 20 and I have assigned a static ip, from this pc in vlan 20 I can ping your gateway 172.20.0.1, but I can not ping any pc in vlan 1 or 172.16 .0.3. From a pc in vlan 1 I can ping vlan 20 172.20.0.1, but I can not ping the pc I assigned in vlan 20. Should I create a route? in cisco for a layer 3 switch you have to type the command "ip routing", do you have to do something similar or is it something of routing? I appreciate your help.
  • 2.  RE: Routing between vlan switch layer 3 hp
    Posted Oct 07, 2018 10:21 AM
    What model of HPE switch are you using?
  • 3.  RE: Routing between vlan switch layer 3 hp
    Posted Oct 07, 2018 10:58 AM
    Hello Friend. It is the following model: HP A5120-48G JE069A.
  • 4.  RE: Routing between vlan switch layer 3 hp
    Posted Oct 07, 2018 11:13 AM
    IP routing is enabled by default on the HPE 5120's so you don't need to explicitly enable routing.
    This could be a configuration issue. Create IP interfaces for the two VLANs on the switch and try to do source pings.
    <HP5120>ping -a <source ip> <dest ip>
    If successful inter-VLAN routing is working. You ay want to focus on configuration.
    Hope this helps.
