Hi all,
we have core switch 5406r zl2 & Aruba 1930 ION and wants to make routing between VLANs on the core, so I configure VLANs and interface VLANs and enable IP routing then I tested it but I can't reach any VLAN. at some point when i assigned my laptop to any VLAN, I can reach my Vlan GW but after while I can't. I added a static route but I removed it. hope to help me to find a solution to this issue.
here the configuration :
Running configuration:
; J9850A Configuration Editor; Created on release #KB.16.07.0003
; Ver #14:01.4f.f8.1d.fb.7f.bf.bb.ff.7c.59.fc.7b.ff.ff.fc.ff.ff.3f.ef:4e
hostname "HP-Switch-5406Rzl2"
module A type j9987a
module B type j9987a
trunk A9-A10 trk1 lacp
trunk A11-A12 trk2 lacp
trunk A13-A14 trk3 lacp
trunk A15-A16 trk4 lacp
trunk A17-A20 trk5 lacp
trunk A21-A22 trk6 lacp
trunk B1-B2 trk7 lacp
trunk B3-B4 trk8 lacp
trunk B5-B6 trk9 lacp
trunk B7-B8 trk10 lacp
trunk B9-B10 trk11 lacp
trunk B11-B12 trk12 lacp
trunk B13-B14 trk13 lacp
trunk B15-B16 trk14 lacp
trunk B19-B20 trk15 lacp
ip routing
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
exit
vlan 1
name "DEFAULT_VLAN"
no untagged A1-A8
untagged A23-A24,B17-B18,B21-B24,Trk1-Trk15
ipv6 enable
ipv6 address dhcp full
exit
vlan 10
name "VLAN10"
tagged Trk5-Trk14
ip address 172.18.10.254 255.255.255.0
exit
vlan 11
name "VLAN11"
tagged Trk5-Trk14
ip address 172.18.11.254 255.255.255.0
exit
vlan 12
name "VLAN12"
tagged Trk5-Trk14
ip address 172.18.12.254 255.255.255.0
exit
vlan 13
name "VLAN13"
tagged Trk5
ip address 172.18.13.254 255.255.255.0
exit
vlan 14
name "VLAN14"
tagged Trk5
ip address 172.18.14.254 255.255.255.0
exit
vlan 15
name "VLAN15"
tagged Trk5
ip address 172.18.15.254 255.255.255.0
exit
vlan 20
name "VLAN20"
untagged A7-A8
tagged Trk5-Trk14
ip address 172.18.20.254 255.255.255.0
exit
vlan 25
name "VLAN25"
tagged Trk5,Trk15
ip address 172.25.25.25 255.255.255.0
exit
vlan 40
name "VLAN40"
tagged Trk1-Trk5
ip address 172.18.40.254 255.255.255.0
exit
vlan 41
name "VLAN41"
untagged A2-A6
tagged Trk5-Trk14
ip address 172.18.41.254 255.255.255.0
exit
vlan 49
name "VLAN49"
untagged A1
tagged Trk5-Trk14
ip address 172.18.49.254 255.255.255.0
exit
vlan 50
name "VLAN50"
tagged Trk1-Trk14
ip address 172.18.50.254 255.255.255.0
exit
vlan 100
name "VLAN100"
tagged Trk1-Trk14
ip address 172.18.100.254 255.255.255.0
exit
vlan 111
name "VLAN111"
tagged B17-B18
ip address 172.18.111.100 255.255.255.0
exit
vlan 112
name "VLAN112"
tagged B17-B18,Trk5
ip address 172.18.112.100 255.255.255.0
exit
vlan 192
name "VLAN192"
tagged Trk5-Trk14
ip address 192.168.0.1 255.255.255.0
exit
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
spanning-tree Trk3 priority 4
spanning-tree Trk4 priority 4
spanning-tree Trk5 priority 4
spanning-tree Trk6 priority 4
spanning-tree Trk7 priority 4
spanning-tree Trk8 priority 4
spanning-tree Trk9 priority 4
spanning-tree Trk10 priority 4
spanning-tree Trk11 priority 4
spanning-tree Trk12 priority 4
spanning-tree Trk13 priority 4
spanning-tree Trk14 priority 4
spanning-tree Trk15 priority 4
Amr Ragab
