Wired Intelligent Edge
  • 1.  RSTP between Comware & ArubaOS
    Posted Aug 17, 2020 05:30 AM
    Hi
    I have network base on comware 5 switches (like hp3600) and Core HPE5940 with comware 7. this network based on rstp.
    We recently purchased aruba 2930f switches and have difficulty integrating them with the STP protocol. The 2930f Crowns himself to the root.
    The configuration on the Aruba:
    spanning-tree enable
    spanning-tree mode rapid-pvst
    spanning-tree force-version rstp-operation
    The configuration on the 5940:
    stp global enable
    stp mode rstp
    stp instance 0 root primary
  • 2.  RE: RSTP between Comware & ArubaOS
    Posted Aug 17, 2020 06:01 AM
    Without knowing too much about your setup as a first step  on the Aruba 2930F
    I amuse you dont want the 2930F as the root.
    Try increasing the STP priority for the vlan in question in the example below done for vlans 1-3 (version 16.10)
    spanning-tree vlan 1-3 priority 15
    I also note you are mixing MSTP and RSTP on the Comware device as far as I can see.
    This may also be causing your issue please refer to the documentation for your version to clarify  i.e
    1. Comware in STP/RSTP  the command for root is:-  stp root primary
    2. Comware in PVST the command for root is:- stp vlan [vlan list] root primary
    3. Comware MSTP the command is:- stp instance [instance list] root primary
    Id recommend testing  this in a lab/dev/test environment first or seek help from a authorised partner before you go live.
  • 3.  RE: RSTP between Comware & ArubaOS
    Posted Aug 17, 2020 07:10 AM
    It did not solve the problem
    Still the 2930f thinks it is the root
    But the 5940 didn't block the uplink although we config STP root-protection
    The switch translate the command "stp root primary" to "stp instance 0 root primary"
    I double check the config on the comware and it's spanning mode is RSTP (comware does not support RPVST)
  • 4.  RE: RSTP between Comware & ArubaOS
    Posted Aug 17, 2020 09:44 AM
    Ronelsh
    I was checking you have rstp v mstp and yes acknowledged stp  root primary does show in final config as stp instance 0 root primary
    Having said that Comware does support rapid pvst on upstream/downstream when Comware is in rstp and neighbour is in rapid-pvst, this being your case.
    Here is my working config with the Comware device working as root.
    I only have vlan1 running.
    Comware
    stp mode rstp
    stp global enable
    ArubaOS
    spanning-tree
    To check this I have a luxury of a small lab and I could flip the root by manipulating the cost on Comware, as an FYI (do not try this in your live environment)
    Comware
    undo stp root
    stp priorty 61440
    This makes the ArubaOS switch root as its default cost is 32678 (8X4096,  8 is default ), the Comware box having 61440.
    Id suggest contacting support so they can help you dig deeper.
  • 5.  RE: RSTP between Comware & ArubaOS
    Posted Aug 18, 2020 03:03 AM
    Hi Ronelsh,
    for me it doesn't make sense to use Rapid-PVST Mode on the ArubaOS-Switch devices as this a mode designed for compatibility with Cisco switches. It calculates one spanning tree per vlan. But you want to have a network wide spanning tree together with the comware switches, thus one instance for all switches.
    ArubaOS-Switch devices offer two modes: mstp and rapid-pvst. First you should change to mstp mode on the 2930s. In mstp mode, you can select VERSION "stp-compatible" for legacy STP (802.1D-1998), "mstp-operation" for 802.1s MSTP and "rstp-operation" for RSTP (802.1w which is incorporated in 802.1D-2004, the current STP standard).
    So the config should look like this:
    spanning-tree mode mstp
    I would furthermore recommend to use on all comware switches the following command in addition to the config you already have:
    stp pathcost-standard dot1t
    This will set the default pathcosts on comware to the 802.1t metric which is also used on Aruba per default. It ensures all switches have a common understanding of the pathcosts.
    Hope this helps,
    Frank.
  • 6.  RE: RSTP between Comware & ArubaOS
    Posted Aug 18, 2020 04:13 AM
    Hi fanstoet,
    I tested the settings in a lab environment
    This seems to solve the problem:
    There's something I still do not understand
    The command sh spanning-tree show that the
    CST root MAC address: the comware switch
    IST Regional Root MAC address: the aruba himself
    What it means?
  • 7.  RE: RSTP between Comware & ArubaOS
    Posted Aug 18, 2020 07:03 AM
    A Region within MSTP is a group of switches with common configuration. CST is the common spanning tree which interconnects several regions. When you use RSTP this represents a special case in which each switch forms a region of its own and, as there is only one switch in the region, it is the root bridge there.However this is only the mstp perspective which doesn't matter in your case. Important is only the CST root bridge which is the root bridge for your entire L2 domain. If this is the comware switch with prio 0 everything is fine.
    Cheers F.
  • 8.  RE: RSTP between Comware & ArubaOS
    Posted Aug 19, 2020 12:02 AM
    Hi fanstoet,
    Thanks so much for the help!
