Hi Everyone,
When I test RSTP convergence I note ping IP -t replies are intermittent, can someone advise what causes this behavior given the following configuration?
The Arubu switches are 2930M JL322A series and have AV hardware attached.
All switches:
igmp filter-unknown-mcast
We are using VLAN 11 for the AV hosts, which has the command:
ip ipmg
SW-0-1 (Core Layer 2/3 switch)
CST Root Port: This switch is root
SW-0-5 (Edge AV switch)
CST Root Port:48
SW-0-6 (Edge AV switch)
CST Root Port:48
A laptop connected to SW-0-6 and has an DHCP allocated IP address and a ping <IP> -t running.
SW-0-5 and SW-0-6 are connected via an alternate port (47).
bpdu filters exclude data VLAN uplink ports and router outbound port
spanning-tree
spanning-tree 40 bpdu-filter
spanning-tree 45 bpdu-filter
spanning-tree 46 bpdu-filter
spanning-tree 47 bpdu-filter
spanning-tree 48 bpdu-filter
no spanning-tree bpdu-throttle
spanning-tree trap new-root root-guard loop-guard
spanning-tree priority 0 force-version rstp-operation
SW-0-5 and SW-0-6
spanning-tree
spanning-tree force-version rstp-operation
Hope someone can assist. Thank you.
