Wired Intelligent Edge
Rx Discards in the 5406 zl2
This thread has been viewed 16 times
  • 1.  Rx Discards in the 5406 zl2
    Posted 26 days ago
    I am experiencing rx-discard between my HP 5406 zl2 core switch and 2530 48G edge switch.
    There is a 700 MB/s data flow from the core switch to the edge switch. Tx discard is too high at 5406. I'm experiencing freezing in camera images.  There is fiber optic between the core switch and the edge switch. I am using 1 GB sfp. Is there a solution?
    Thanks!
    Core:
    Transceiver in B1
    Interface Index : 33
    Type : 1000LX
    Model : J4859C
    Connector Type : LC
    Wavelength : 1310nm
    Transfer Distance : 10.0km (9um),
    Diagnostic Support : None
    Serial Number : 1604160190
    Status and Counters - Port Counters for port B1
    Name :
    MAC Address : 1c98ec-b030df
    Link Status : Up
    Port Enabled : Yes
    Totals (Since boot or last clear) :
    Bytes Rx : 1,129,566,346 Bytes Tx : 677,259,869
    Unicast Rx : 2,238,367,692 Unicast Tx : 1,239,771,395
    Bcast/Mcast Rx : 197,126,816 Bcast/Mcast Tx : 2,826,942,819
    Errors (Since boot or last clear) :
    FCS Rx : 0 Drops Tx : 1,358,916,298
    Alignment Rx : 0 Collisions Tx : 0
    Runts Rx : 0 Late Colln Tx : 0
    Giants Rx : 0 Excessive Colln : 0
    Total Rx Errors : 0 Deferred Tx : 0
    Others (Since boot or last clear) :
    Discard Rx : 78 Out Queue Len : 0
    Unknown Protos : 0
    Rates (5 minute weighted average) :
    Total Rx (bps) : 35,886,448 Total Tx (bps) : 705,228,568
    Unicast Rx (Pkts/sec) : 29,528 Unicast Tx (Pkts/sec) : 62,718
    B/Mcast Rx (Pkts/sec) : 3 B/Mcast Tx (Pkts/sec) : 435
    Utilization Rx : 03.58 %
    Edge:
    ZK_BH_S1_48_095_cctv(eth-49)# sh int transceiver 49 detail
    Transceiver in 49
    Interface Index : 49
    Type : 1000LX
    Model : J4859C
    Connector Type : LC
    Wavelength : 1310nm
    Transfer Distance : 20.0km (9um),
    Diagnostic Support : DOM
    Serial Number : 1BLBM30
    Status
    Temperature : 38.535C
    Voltage : 3.3220V
    Tx Bias : 20.274mA
    Tx Power : 0.2463mW, -6.085dBm
    Rx Power : 0.4207mW, -3.760dBm
    interface B1
    rate-limit bcast in percent 5
    exit
    vlan 207
    tagged A1-A24,B1-B24,C1-C24,E1,E9-E10,E14-E24
    ip address 192.168.4.1 255.255.252.0
    ip helper-address 10.10.0.2
    ip helper-address 10.10.0.4
    qos priority 4
    jumbo
    exit
  • 2.  RE: Rx Discards in the 5406 zl2
    MVP GURU
    Posted 25 days ago
    So there is a chilometer(s) long distance (or anything longer than 300 at best) between your Core and your Edge switches and the link is 1Gbps. You wrote the traffic flow experiencing the issue ("Drops Tx" on B1 port on the Core switch so it means dropped packets leaving the B1 port to go to port 49 on the Access switch) is pushing 700 Mbps (not MBps) into the link so 70% of the port throughput (any direction), correct?
    Could you post the output of show interface transceiver B1 detail command on you Core switch? given the S/N (compared to the other one) is the J4858C installed there an original OEM one (HP, HPE, Aruba)?
    Is the Single Mode fiber link certified?
  • 3.  RE: Rx Discards in the 5406 zl2
    Posted 25 days ago
    We cannot say that the port efficiency is 70%. When I increase the traffic, it can reach 1000 Mbit.
    Core:
    Transceiver in B1
       Type               : 1000LX
       Model              : J4859C
       Connector Type     : LC
       Wavelength         : 1310nm
    Edge:
    Transceiver in 49
       Type               : 1000LX
       Model              : J4859C
       Connector Type     : LC
       Wavelength         : 1310nm
     Status
       Temperature : 37.914C
       Voltage     : 3.3220V
       Tx Bias     : 20.274mA
       Rx Power    : 0.4343mW, -3.622dBm
  • 4.  RE: Rx Discards in the 5406 zl2
    MVP GURU
    Posted 25 days ago
    I never wrote that "the port efficiency is 70%", I reported what you wrote...the traffic was 700 Mbps on a 1000 Mbps link (arithmetic says that - in that particular moment - the traffic used up to 70% of the link bandwidth, this doesn't mean that it is not going to saturate up to reaching 1000 Mbps).
    Why the J4859C on B1 shows no DOM information? is it original OEM or not?
  • 5.  RE: Rx Discards in the 5406 zl2
    Posted 25 days ago
    Hi @parnassus, Hi @dolanbay,
    i cannot iagine that one of the two transceivers is original HPE.
    1. Transceiver (B1) has a generic serial and reports no DOM (starting with C-Revision there was DOM on Board)
    2. Transceiver (49) shows the wrong allowed distance (20km instead of 10km - see attached screenshot)
    Possible errors could be:
    1. dirty fibre connection (fibre clean needed - both sides)
    2. broken fibre (replace or use of monomode-transceivers
    3. change patch-cable
    4. to much multicast (there is a multicast-limit on the interface - which could result in camera freeze)
       Do the cameras transport video via multicast to the subscribers (security-panel, video-recorder, etc.)
    etc.
    Greetings
    Franz
    prefers to not experiment with live customer equipment...
  • 6.  RE: Rx Discards in the 5406 zl2
    Posted 25 days ago
    We use Longline J4859C 1000Base LX 1310nm 10km SFP Module HP compatible.
    i tired
    int 49 rate-limit mcast in percent 100
    b1 rate-limit mcast in percent 100
    but it didn't work
  • 7.  RE: Rx Discards in the 5406 zl2
    MVP GURU
    Posted 24 days ago
    If I were you (clearly if budget permits) I would use a pair of the original OEM supported (by an updated Aruba 5400R zl2 and and updated Aruba 2530) LX SFP Transceiver by HPE Aruba Networking, that is a pair among those:
    • HPE X121 1G SFP LC LX Transceiver (J4859C) <--------------------------------- preferred
    • Aruba 1G SFP LC LX 10km SMF Transceiver (J4859D) <---------------------- alternative to J4859C
    • Aruba 1G SFP LC LX 10km SMF TAA Transceiver (JL746A) <----------------- Updated AOS-Switch software needed
    • Aruba 1G I-Tmp SFP LC LX 10km SMF Transceiver (JL781A) <-------------- Updated AOS-Switch software needed
    and - in any case - will try without the "rate-limit multi-cast" interface option (at least initially) to see how the connectivity over your Single Mode 9/125 um optic link (=<10 km) behaves.
    For sure original OEM Transceivers support DOM, with non original part there is nothing granted (neither pure performances).
