And this WLAN Platform matrix may help as well.
Original Message:
Sent: Nov 20, 2024 02:27 PM
Subject: Safe to upgrade IAP-325 with 8.12 firmware?
Thanks for the guidance.
Is there a publicly listed web page to check which factory firmware is the latest valid version for the respective IAP models in the field?
ArunK
Original Message:
Sent: Nov 19, 2024 11:20 PM
8.10.0.14 is the latest maintenance release for it.
Original Message:
Sent: Nov 19, 2024 10:03 PM
IAP-325 was "parked" on Instant 8.10 code, and cannot be upgraded to 8.11 or later.
/Onno Harms, Aruba Wireless Product Management
Original Message:
Sent: Nov 19, 2024 09:35 PM
I have a small cluster of IAP-325s running on 8.10. IIRC, factory firmware 8.11 is not compatible with the IAP-325s.
Now I see factory version 8.12 show up in the firmware update page.
Is it safe to upgrade the IAP-325s to 8.12 ?
Thanks for your guidance _()_
ArunK
