Samsung handset connectivity issues
  • 1.  Samsung handset connectivity issues
    Posted Jun 26, 2023 08:17 AM
     We. have a batch. of Samsung handsets running Android 13 that are having issues connecting to a wpa2-enterprise network using eap-tls.
    Basically  they seem to connect. but can't get any traffic to pass. However, by toggling the option to randomise mac addesses they can . Doesnt matter whether they enable mac randomisation for an SSID or disable it, whichever way they do it,  the connection starts working
    Rgds
    Alex
  • 2.  RE: Samsung handset connectivity issues
    Posted Jul 03, 2023 07:08 AM
    Does not ring a bell. Make sure that you are on a recent firmware version (AP/controller), and I would perform packet captures to find the differences between before and after toggling the mac randomization. Aruba Support may assist in this troubleshooting, if needed.
