Hello there,
if you have used the Batch Operation for saving the configuration, there is another way to perform this task. You can create a configuration template for your Huawai switches where you can specify the exact commands that need to be issued on the devices. Please navigate to Service - Configuration Center - Configuration Templates and add one, the content of the template should include the commands for the specific devices.
Thank you,
Best Regards,
Ivaylo
Original Message:
Sent: Nov 22, 2024 10:16 AM
Subject: save configuration HPE IMC huawei switch
hello,
my huawei switches are added to IMC (Std 7.3E0710P06), i can manage them (Mibs) and backup them (adapter file) but the save configuration function is not working ( "Save" in CLI, equivalent to "wr mem" for cisco or aruba).
i only have "failure" in details.
i can't see any information about that.
any idea?
thank you
