Network Management
save configuration HPE IMC huawei switch
  • 1.  save configuration HPE IMC huawei switch
    Posted Nov 25, 2024 05:22 AM
    hello,
    my huawei switches are added to IMC (Std 7.3E0710P06), i can manage them (Mibs) and backup them (adapter file) but the save configuration function is not working ( "Save" in CLI, equivalent to "wr mem" for cisco or aruba).
    i only have "failure" in details.
    i can't see any information about that.
    any idea?
    thank you
  • 2.  RE: save configuration HPE IMC huawei switch
    Posted Nov 26, 2024 02:15 AM
    Hello there,
    if you have used the Batch Operation for saving the configuration, there is another way to perform this task. You can create a configuration template for your Huawai switches where you can specify the exact commands that need to be issued on the devices. Please navigate to Service - Configuration Center - Configuration Templates and add one, the content of the template should include the commands for the specific devices.
    Thank you,
    Best Regards,
    Ivaylo
