Comware
  • 1.  Schedule Reboot FlexFabric 5700
    Posted Apr 05, 2016 02:47 AM
    I wanted to do a scheduled reboot with a 5700er IRF-Stack but i only get an error message:
    08_00_09-admin@10.140.20.1.png" alt="2016-04-05 08_00_09-admin@10.140.20.1.png">
    Anyone have an idea why the Stack won´t reboot. I do the scheduler reboot at or delay command which is documentated in the manual.
  • 2.  RE: Schedule Reboot FlexFabric 5700
    Posted Apr 06, 2016 10:39 AM
    We have had some issues with the scheduled reboot before.  I had a case with the VSR for exactly that.
    When you request help on this, it is really important to tell us what software version you are running.  SO.... what version are you running?  I can try it on one of my 5700's in my lab.
    David
  • 3.  RE: Schedule Reboot FlexFabric 5700
    Posted Apr 07, 2016 02:06 AM
    Hi David,
    I tested with 3 different 5700er IRF-Stacks all the same System image version: 7.1.045, Release 2418P06
    Thanks for your support.
