Network Management
Script exist error - "missing close-brace"
  • 1.  Script exist error - "missing close-brace"
    Posted Jul 15, 2022 10:37 AM
    Hi
    I downloaded new software on my IMC for switch type 2930F, wc_16_11_0004.swi and tried to update one of my manny switches - but get a fail, see Attachment
    Attachment(s)
    txt
    Script exist error.txt   1 KB 1 version
  • 2.  RE: Script exist error - "missing close-brace"
    Posted Aug 16, 2022 01:47 PM
    Hi try below method
    1. Login to iMC, go to Service -> Configuration Center -> Software Library
    2. Check if required firmware file is available in library. If not, use "Add" button to load firmware file in IMC. If available, select the file and click on "Deploy"
    3. Default file transfer mode (Service>Configuration Center>Options) needed to be changed from TFTP to SFTP. Under Single Device Transfer Mode select device and set that device on SFTP mode.
    4. Click on "Select device", browse using type or IP address. Select appropriate device.
    5. Device will be visible under the list. Use appropriate one or more device types.
    6. Click next, it checks and shows if sufficient space is available in memory.
    7. Under "Set task attributes", give any name or it will take automatic one. Schedule time or select "Immediately".
    8. Verify summary of the task and click "Finish"
    9. Select task and click "Execute" if required
    10. Once the task is executed successfully, check firmware on device.
