SD-WAN
  • 1.  SD-Branch - ISP traffic Failover
    Posted Jun 27, 2024 11:08 AM
    We have setup with Dual Gateways at Remote site GW1 and GW2. Both are in cluster and VRRP is enabled. Also, Each Gateways are connected to different ISPs ISP1 and ISP2. Here, If ISP1 fail means, entire site went down. Our intention is when ISP1 down means it will failover to GW2 ISP.
    While the issue comes , we manually go to Gateway and make GW2 as Master. Is this expected behavior? Also what will be the best practice for Auto failover traffic. Please suggest.
    Madhankumar M
  • 2.  RE: SD-Branch - ISP traffic Failover
    Posted Jun 27, 2024 07:55 PM
    I am assuming you are talking about branch gateways 9004, etc. if thats the case then you can refer to this Aruba Branch Gateway Redundancy technote
  • 3.  RE: SD-Branch - ISP traffic Failover
    Posted Jun 28, 2024 12:18 AM
    Thanks. Very helpful in this design document.
