Hello community!
I recently faced an issue with the following topology:
- 1 VPNC with 2 WAN uplinks (nat 1:1 behind a fortigate firewall)
- 1 Branch gateway with 1 WAN uplink (directly connected)
- VPNC and Branch gateway share the same ISP provider (ISP-A)
Under normal circumstances, Branch GW will establish one tunnel from
ISP-A to
ISP-A.But what if ISP-A from VPNC goes down?
The orchestrator won't bring up a new tunnel from Branch GW
ISP-A to VPNC
ISP-B I had to delete WAN ISP-A from the VPNC to force the orchestrator create new tunnels using the working WAN uplink (ISP-B)
This can't be expected behavior, right?
Thank you in advance!
