Cloud Managed Networks
  • 1.  sd-branch vGW 8.x certicate error
    Posted Nov 26, 2023 01:48 PM
    I'm trying to use sd-branch vGW 8.x images to emulate and learn the solution using EVE-NG/GNS3.
    But I keep running into this certificate error (screenshot attached) when the vgw is booted up. The issue causes the vgw to loop the ZTP continuously.
    Can someone help me fix it?
    FYI - The issue doesnt occur with 10.x images.
  • 2.  RE: sd-branch vGW 8.x certicate error
    Posted Nov 27, 2023 02:04 AM
    Found the solution.
    I had to change the KVM Qemu version to 4.1.0 to make it work.
