The 7205 is not supported in the SD-Branch / WAN solution. 7010 as branch gateway and VPNC is fine.
I suggest you to contact you Aruba SE about this. The SD-WAN feature in Central is not visible for everyone one, only for whitelisted customers. Also you topology needs to be reviewed by the SD-Branch team.
