SD-WAN
  • 1.  SD-WAN Gateways WAN ports
    Posted Dec 07, 2020 10:35 AM
    Hi all,
    i would like to know how many of the ports of an aruba sd-wan gateway can act as a WAN port.
    For example, the 9012 has 12 ports. Those ports are LAN ports, WAN ports or both , so you can have every combination you like?
    Thanks!
    Alexandros Gkanas
  • 2.  RE: SD-WAN Gateways WAN ports
    Posted Dec 07, 2020 06:10 PM
    You can have 4 WAN uplinks configured (under WAN --> uplinks) so that is going to limit you more. One WAN VLAN is also considered an uplink so it's not physical port limit.
  • 3.  RE: SD-WAN Gateways WAN ports
    Posted Dec 07, 2020 07:32 PM
    yes you can have 4 WAN uplinks plus 1x USB based 3G/4G
