Become a Member
Hy
I installed the VAN SDN Controller Version 2.5.15.
The following applications are no embeeded in the controller:
- Link Manager
- Node Manager
- Topology Manager
- Topology Viewer
How can I install these applications?
Payton,
Thank you for contacting HP SDN Forum. At the moment I am researching your question and I will get back to you as soon as possible.
Best Regards,
CoE/SDN Team
Carlos
Carlos, do you have any ideas?
I am still researching this with our engineering department. But, based on the HP VAN SDN Controller Release Notes 2.5.15 it states that "Topology Viewer Classes" have been removed from the topology viewer package. You can find this information on page 7 and 10. I will respond as soon as possible once I find out more on the rest of the APIs.
HP SDN engineering states they need to update the document to list only the four applications that you are seeing. The remaining four are now 'internal' applications and won't show up in that list any more.
CoE SDN Team
Hi I have also upgraded to 2.5
I dont think those application are available in 2.5, but my application thats was built with 2.4 version still worked in 2.5
