I am trying to delete a flow in the VAN controller using DELETE REST call, something like below:
curl -sk -H "X-Auth-Token:6b2fa61a754a4cb984cc943689e65276" -X DELETE -H 'Content-Type:application/json' -d '{"flow":{"priority":50000,"idle_timeout":200,"match":[{"eth_type":"ipv4"},{"ipv4_src":"10.0.0.1"},{"ipv4_dst":"10.0.0.2"},{"ip_proto":"tcp"},{"tcp_dst":"80"}],"actions":[{"output":2}]}}' https://127.0.0.1:8443/sdn/v2.0/of/datapaths/00:00:00:00:00:00:00:01/flows
Using curl command, this works fine. Is there a similar way in Java (library/package etc.), which can be used to do the same?
I have tried the common Http client libraries of Java but unable to implement the DELETE method with payload. Please help.
