From you screenshot I can see that ClientMatch is disabled. You should enable this without changing the Default Parameters.
You will find the Roaming experience in the Client Details View at the bottom.
802.11r will be enabled / disabled in the WLAN Settings of the SSID on Security Tab.
Your Screenshot of AI Insight is not really helpful. You can´t see the numbers of Radar detection, Errors, etc.
CLI Output ofshow ap neighborsshow ap arm historyshow clientswould be nice to seeYou also can open a TAC Case.
Original Message:
Sent: Jan 12, 2023 08:43 PM
Subject: Seamless roaming for users
How do i fine tuned the Client Match settings ?
What is the Roaming Dashboard of the Client saying? Do you see high latency Roaming?
Where do i find the Roaming Dashboard in Aruba Central ?
Any AI Insights regarding Client Roaming?
What type of clients are having issues?
windows 10 laptops
What Software Version are you using?
Did you enable 802.11r/k/v? - in my experience some Clients have issues with activated 802.11r, so if enabled, disable it for testing.
is this on clients machine
How are Clients authenticating?
using EAP-TLS certs on windows laptops and mac filtering on mobile devices
Original Message:
Sent: Jan 12, 2023 08:27 AM
Yes you can, when you are on 6.x or 8.x
https://www.arubanetworks.com/techdocs/central/latest/content/nms/access-points/cfg/radio-mgmt/conf_arm_features.htm?Highlight=clientmatch
Output of
show ap neighbors
show ap arm history
show clients
Original Message:
Sent: Jan 12, 2023 08:05 AM
APs are about 5 metres apart.
AP-303. we are using Aruba Central to managed the APs.
Can I turn on ClientMatch if I am using Aruba Central ?
Original Message:
Sent: Jan 12, 2023 03:55 AM
How far are those APs away from each other?
What are you using? Controllerless or controllerbased WiFi?
Have you turned ClientMatch on?
See the following Document for additional suggestions - https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=9b71b25a-80a1-4851-8b5f-21fdc9ab083f
Original Message:
Sent: Jan 12, 2023 03:14 AM
Is there anything I can do on the Aruba AP for more seamless roaming of WIFI access, when users switch AP1 to AP2 nearby?
currently when user switch to different AP, they will noticed a drop in WIFI connection.
