Network Management
Secondary login as local did not work until Disable Radius Client on NPS
  • 1.  Secondary login as local did not work until Disable Radius Client on NPS
    Posted Mar 16, 2023 10:59 PM
    Dear Friends,
    I would like to find out why my secondary login is not working on my Aruba 2930M switch. Every time I have to disable Radius Client on NPS server, so can log in as local users. I remember on Aruba CX 6900, it has Authentication Fail through....
    Here is my result of Show Authentication:
    Status and Counters - Authentication Information
    Authorized enabled as backup for secondary login are preceded by *
      Login Attempts : 2
      Lockout Delay : 0
      Respect Privilege : Enabled
      Bypass Username For Operator and Manager Access : Disabled
                     | Login       Login        Login
      Access Task    | Primary     Server Group Secondary
      Console        | Local                    None
      Telnet         | Local                    None
      Port-Access    | ChapRadius  radius       None
      Webui          | PeapRadius  radius       Local
      SSH            | PeapRadius  radius       Local
      Web-Auth       | ChapRadius  radius       None
      MAC-Auth       | ChapRadius  radius       None
      SNMP           | Local                    None
      Local-MAC-Auth | Local       radius       None
      REST           | Local                    None
                     | Enable      Enable       Enable
      Telnet         | Local                    None
      REST           | Local                    None
    Any idea why?
    Thanks a lot
