Seeing devices on hospitality AP switchports
  • 1.  Seeing devices on hospitality AP switchports
    Posted Oct 06, 2020 02:14 PM
    AOS 8.6.0.5
    One of our customers (we have a federated environment) uses a lot of AP-303Hs, the AP ports don't authenticate devices, but are available for use. The ports work fine. But they are having some network issues and it would be very helpful if we could see the wired devices on those APs in the user table on the controller (or access them some other way).
    I think I have to make the wired-ap-profile 'Not Trusted' and apply an ACL, but am stuck at the 'apply an ACL' bit! I see there is an option to add an AAA profile to the wired-port-profile, is that what I need to do? Or am I going about this the wrong way?
    Thank you,
    Guy
  • 2.  RE: Seeing devices on hospitality AP switchports
    Posted Oct 06, 2020 03:40 PM
    Yes, make the wired profile untrusted and assign the AAA profile
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Seeing devices on hospitality AP switchports
    Posted Oct 06, 2020 04:26 PM
    Thank you - and is it the Initial Role that I want to set in the AAA profile?
  • 4.  RE: Seeing devices on hospitality AP switchports
    Posted Oct 06, 2020 08:51 PM
    Yes.
